n_damian
Oct 31, 2016Aspirant
Readynas Pro 2 max memory
What is max memory (ddr3) size which i can install with one slot (rndp2000)?
- n_damianAspirant
OS6
- JennCNETGEAR Employee Retired
Hello n_damian,
Are you running OS6 on your ReadyNAS Pro 2?
This discussion might also help: ReadyNAS RAM Upgrade - Needed?
- n_damianAspirantYes, i'm using OS 6 on RNDP2000.
RAM is cheap so I want to install 4GB. I know that 2GB will work, but what about 4 GB? - dsinghAspirant
Hi has anybody tried the following on Readynas Pro2 running OS6? Do you think that it will work?
https://ptarmiganlabs.wordpress.com/2013/08/16/add-more-ram-memory-to-readynas-rn312/
The following looks promising if 4GB works on the Pro2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231341
- dsinghAspirant
The following look promising if 4GB works on the Pro2
