Shields92's avatar
Shields92
ReadyNAS Pro 2 Remote access Help
Hello, I know the ReadyNas Pro 2 is outdated pretty much and was wondering if I could still use the IP address to port Forward it to access it from anywhere. I know very little about networking but I...
  • StephenB's avatar
    Mar 20, 2018
    ReadyNAS Remote is discontinued, so that is not an option.
    Port forwarding is possible, but you'd need to give us more information about what services you want to use remotely.  ReadyDLNA can't be forwarded, and SMB/CIFS shouldn't be.
    Another option is to use a VPN.  Some routers have a built-in VPN service (for instance Netgear Nighthawk and Orbi Routers).  What router are you using?
    Also, you can convert your Pro-2 to run OS-6.  That would give you the option of running ReadyCloud.  The process requires a factory default, so you would need to back up your files before doing that.
ProSupport for Business
