wsbbb07
Aug 10, 2018Follower
ReadyNAS Pro 4 zero bytes available after fw update, no failures
Hello!
My ReadyNAS Pro 4 [X-RAID2] was auto-updated to fw RAIDiator 4.2.31, and after that I see "Zero bytes available" when connecting to device via AFP (files are available but can't write a new ...
Aug 13, 2018Guru - Experienced User
wsbbb07 wrote:
And, I can't downgrade fw version because "update file is not valid for this architecture". Please help!
What are you trying to downgrade to?
wsbbb07 wrote:
Admin console shows that all is OK and 74% of 8326 GB used.
Do you have write access if you use SMB?
Are there any issues in the log related to filesystem errors?
It would be wise to back up the files.
- mdgm-ntgrAug 13, 2018NETGEAR Employee RetiredIf it’s a 4.2.x firmware you’re trying to downgrade to this would suggest that your 4GB root volume might be full.
Unless you already have SSH installed this would need to be fixed via tech support mode.
Which services are you running?
Do you have any add-ons installed?
