regnav's avatar
regnav
ReadyNas Pro 6 and drive question
Pro 6 with 3 x Barracuda ST32000542AS SATA 3gb/s - starting to get high error counts on one of the drives. Prices for these old drives are crazy. Can get Barracuda ST2000DM001SATA 6gb/s the same size for half the price. Any issue running same size and mfg, but different model in and xraid group? Understand no issue with 3 gb/s controller and 6 gb/s drives, will just run at 3gb/s. Not sure on the different models in xraid, however.
Thank You
Pro 6
x-raid2
RAIDiator 4.2.24
Memory: 1024 MB [6-6-6-18 DDR2]
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You can use different disk models in the same unit, but be sure to choose disks from the compatibility list.
ProSupport for Business
