oshae
Oct 07, 2014Tutor
ReadyNAS Pro 6 Power Supply
I read somewhere on the forum that if the power supply in the Pro 6 dies the whole chassis has to be replaced. Could I just get some clarification from someone who owns one if this an issue of warr...
Sandshark
Oct 25, 2014Sensei
I replaced the supply in an older Pro, which is essentially the same as the Pro6, and it was actually not too difficult. I used the one you linked to and an 8" ATA supply cable extender. In the end, I wished I'd gone with a 6" extender. I did cut all the other cords short and installed the 90° connectors from the original supply (after installing with the original connectors to insure it worked). I didn't want to leave all the extra cables in there and have them affect air circulation.
