oshae
Oct 07, 2014Tutor
ReadyNAS Pro 6 Power Supply
I read somewhere on the forum that if the power supply in the Pro 6 dies the whole chassis has to be replaced. Could I just get some clarification from someone who owns one if this an issue of warr...
Sandshark
Dec 03, 2014Sensei
Based on the dimensions and picture on the Silverstone site, it appears it should physically fit. It's the same as the Seasonic except without the fan portion sticking out, but that's fine. The cable configuration and length, however, are different. Depending on just how you measure it, the 24-pin ATX cable length is about 50mm shorter. That's gong to need a longer extension, but I don't think it puts the junction point at a bad spot. It also only has 2 4-pin MOLEX connectors instead of the required 3, and they are on the same wire bundle (which is probably OK). But it has SATA and floppy cables that could be converted to Molex (the right-angle connectors on the original supply are easily moved, or you can buy them on eBay).
If you decide to get one, let us know how it works out. I have a spare Seasonic, but others may need another source if sources for it one dry up.
