Sunfox1's avatar
Sunfox1
Tutor
Feb 02, 2019
ReadyNAS Pro 6 suddenly in reboot loop.... dead?
I have an old ReadyNAS Pro 6 that's been working perfect for ages. Then, today, while writing some files to it, it suddenly died on the network. A few minutes later it came back, I logged in and saw ...
  • Sunfox1's avatar
    Sunfox1
    Feb 05, 2019
    Okay, so my power supply finally arrived (guaranteed Sunday from Amazon's own delivery service, but didn't come until Tuesday - grrr!)
    I purchased the Thermaltake Toughpower SFX 450W.
    First, it works! Got it installed (more on that below), pressed the power button... and all 6 drives initialized, it booted up, and it's currently in resync (due to all the crashes). Not hooked up to network yet (will take it down to my network room and its bonded connections in a couple hours, have something else to do first) so I haven't checked the web interface.
    Second - I wouldn't recommend this power supply for the Readynas. I bought it primarily because it was available same day delivery, but also because it's 450w, 80 plus gold certified, modular, has a 7 year warranty, and uses Japanese capacitors. Sounds great, right?
    And yet it doesn't fit that well. It has to be installed "backwards" (power supply input on the opposite side of the case as the original, but thankfully the wiring harness has enough slack to accomodate), otherwise the cooling fan is INSIDE the case and the rear case fan hits the modular connectors. Installed the other way, the cooling fan is offset and about 1/3 blocked by the chassis (although airflow is probably adequate). Also, the modular cables are NOT sleeved; they're ribbon style which really isn't ideal. Finally, it does require a 24-pin extension (3-4" would be enough) and as there's only 2 Molex, a SATA to Molex adapter.
    I'll keep an eye on the temps for a bit, but otherwise I hope this will keep it going a while longer.
ProSupport for Business
