nran29
Nov 10, 2020Aspirant
Readynas pro 6 volume issues
Hi all, I just replaced 2 dead drives in our Nas and now it's saying "no volume exists. some menu options are available only if a valid volume exists". Also, when trying to perofrm a volume scan ...
nran29
Hello,
RAID 6
Firmware: 4.2.31
Nov 10, 2020Guru - Experienced User
nran29 wrote:
RAID 6
You are using FlexRAID?
I suggest downloading the full log zip file, and see if there are any disk errors on the remaining drives in the logs.
- nran29Nov 10, 2020Aspirant
I dont believe so. How can I verify?
I have downloaded the logs. Is there a specific log file that shows disk errors? Judging by the interface all drives are green.
- StephenBNov 10, 2020Guru - Experienced User
You can look in system.log and kernel.log for disk errors.
You can also look at disk_smart.log for SMART errors.
only errors i see in system log are: kernel: sky2: probe of 0000:01:00.0 failed with error -1
Is it safe to post all logs here?
