Cliffs
Oct 17, 2024Tutor
ReadyNas Pro Business downgrade from OS6 to Radiator 4.3 failed no web access now after factory rese
Trying to breathe life into my old Readynas Pro Business Edition.
I am hoping for a simple solution, I had OS6 running yesterday after upgrading from last Radiator version 4.3 and realised I did not update the BIOS
I did the downgrade back to radiator RAIDiator-x86-4.2.31-downgrade file but now after FW install and factory reset no Radiator Web page, I can see the Readynas on the network with its IP address on a IP scanner but that's it
Have I bricked this or is there an escape,
I removed the drives but as they are now BTRFS radiator can't read them anyway.
Appreciate any suggestions
Otherwise just sell it as not working I guess
Cliff
I figured it out I didn't realise I needed to have at least one disk installed , finally got back to 4.2 installed the BIOS update and in the process of going back to OS6. My ReadyNAS Pro Business lives again.
Only 1G of ram might need a small update most of the DDR2 Ive found is expensive for what it is.
Cliff
- CliffsTutor
Cliff
4 GB modules are rare and expensive. They also often don't work in the NAS.
2 GB modules are still readily available and inexpensive, and would allow you to upgrade it to 4 GB total.
- CliffsTutorOk I’ll start looking for 2gb ram have to check compatibility ddr2 dimm 1066 mhz I think are the main specs
