laalves1
Jan 23, 2015Aspirant
ReadyNAS Pro Business Edition died #24586841
Hi all, Yesterday night my NAS died. Turned itself off and that was it. Does not turn on no matter what I do. Took the PSU out to have a look inside: no bulged capacitors. Shorted green to ground ...
laalves1
Hi, no I didn't remove the drives. Should I try that? How do I ensure I don't loose data? And yes, I tried a different outlet and different cable. I also measured voltages in the cable, in the contacts of the PSU inlet and in the switch. Power is reaching the PSU and, as I said, the PSU boots if I force it to, disconnected from the ReadyNAS and all its voltages measure ok in its plugs (3.3, 5, 12, etc)
