muggsy
Oct 31, 2011Aspirant
ReadyNAS Pro Business eth ports + sys fan failed [17039386]
Hi, Just opened a new case via neteagr support portal. I have a ReadyNAS Pro which has been working flawlessly until today. Midway thru streamng media it dropped off the network. Rebooted my switch a...
Sunday_Afterno1
Nov 05, 2011Aspirant
Absolutely! I recently submitted a support request for my ReadyNAS Pro BE regarding the psu fan beginning to sing/squeak. Basically the bearings are beginning to go and I was hoping that there is a way to swap the fan. Turns out there isn't a user way to do this and support almost immediately issued an RMA to replace the chassis. Given your description, it sounds like you have a hardware problem that should be taken care of by the warranty.
PapaBear is right - get back in touch with support.
