Denis1's avatar
Denis1
Tutor
Apr 23, 2022
ReadyNAS Pro Business NAS power supply
I have ReadyNAS Pro Business (six drives) and it will not turn on, no power.  I believe it's the power supply, it's been running for what 13+ years, I believe. So, I'm looking for a solution.   Can...
  • Sandshark's avatar
    Apr 24, 2022
    The power supply is usually the first thing to go, and you got a long life from yours.  So, your diagnosis is likely correct.
    That's a hugely overpriced supply, though it should work.  The stock supply is auto-switching from 120V to 230V. But few need to move from one to another, so a switch (which you won't be able to access external to the NAS) for that is usually acceptable.
    The ReadyNAS Pro6/Ultra6 power supply is a standard SFX form factor supply except that the cable is longer and it has 3 Molex 4-pin connectors where many no longer do.  But those are easily fixed with a 6" ATX 24-pin extender and either SATA to Molex adapters or Molex splitters.  While the original supply is rated at 300W, it has more 12V available (for the drives) than most of that rating.  So, I recommend at least a 350W replacement, and typically use 400W or 450W myself.  I've used this one with success (though from another supplier): https://www.neweggbusiness.com/product/product.aspx?item=9siv2d7hsm1674&tpk=9siv2d7hsm1674 .  With the necessary adapter and extender, of course.  It has only 2 4-pin Molex connectors.
    Or if you don't want to mess with adapters, you can get a modified supply on eBay for about half what they are asking in the listing you linked.
ProSupport for Business
