sjshumaker
May 05, 2018Follower
ReadyNAS Pro Business Upgrades
Recently acquired a ReadyNAS Pro Business model (RNDP6350-100) with 6x750GB HDDs in excellent shape for almost free. Original owner added a second RAM stick to give it 3MB total but did no otehr up...
Musso
May 07, 2018Aspirant
I've currently got the following spec in the ReadyNAS Business Edition and was thinking about upgrading the CPU. Found elsewhere in the forum that I would need the BIOS updating first then could upgrade to OS6. Any recommendations for the CPU? Some people seem to have fitted a Xeon in there which was a surprise! but willing to go up to whatever is suitable for cooling/power etc.
Product Version: 10/03/2008 FLAME6-MB V1.6
BIOS Version: 080014
BIOS Date: 10/03/2008
CPU: Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
CPU Family: 6
Model: 21
Stepping: 0
Model Name: Genuine Intel(R) processor 1.06GHz
CPU MHz: 1066.632
Cache size: 256 KB
KInd regards
Musso
Sandshark
May 09, 2018Sensei
Unless you plan to do a lot of streaming with transcoding, the quad-core Xeon is very much overkill. And, frankly, if it doesn't get very hot on you with the factory CPU cooler, you're probably not using it to anything close to it's potential, so it's a waste.
I've gone with the Core2 Duo E7500 (2.93GHz) on my older Pro units. The Pentium Dual-Core CPU E5300 (2.60GHz) on the Pro6 doesn't get enough extra bang from the Core2 to make it worthwhile, IMHO.
You do need BIOS version 2.0 if you go with the Core2 or Xeon, so make sure you do that update first.
- MussoMay 09, 2018Aspirant
Thanks Sandshark,
I was have ordered the Core Duo CPU you mentioned as thought the Xeon might have cooling issues (but I have seen people seem to be using it ok in upgrades). Where would I download BIOS V2? Many thanks for the information.
Kind regards
Musso
- mdgm-ntgrMay 09, 2018NETGEAR Employee RetiredFirst check bios_ver.log to see if you already have the latest BIOS dated 07/26/2010.
The add-on is http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin- bedlam1May 09, 2018Prodigy
Message 7 above shows that the latest Bios Version is NOT installed and requires updating
