kekegsm's avatar
kekegsm
Guide
Mar 28, 2017
ReadyNAS pro: Q6600 working, E7600 not...
Hi All,
I bought an used ReadyNAS Pro.
The last owner changed the CPU to Q6600, the CPU cooler to a Schyte Kodati. But for me the E7600 enough, and use less power/make less heat. 105W vs 65W, that is much.
The problem is: The NAS working with Q6600 like a charm, but if I replace CPU, no boot. Just the fans running on max, and READYNAS only on LCD. Cant reset, cant make anything.
What can I do?
ProSupport for Business
