zackiv31's avatar
zackiv31
ReadyNAS Pro turned itself off + Ticking PSU Fan - #19246423
So I wokeup yesterday and my ReadyNAS Pro Pioneer was off for the first time in 9 months. I have it connected to a supported UPC, and everything checked out there.
So I turned it on, and I started hearing a little whirring noise coming from the PSU. I turned it off and took some compressed air to it, and confirmed it was the bottom fan on the back making the noise. It booted up fine, but I can't find anything in the logs as to why the unit shut down. The noise isn't too horrible at this point, but the unfortunate timing of the shutdown + fan noise has me worried that it may be dying.
Does anyone know what might be going on with my unit? Where can I look in the logs for info about why it shut down? I'm still within warranty, if sending it in is the best solution (and how is that done?)
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Open a support case at my.netgear.com explaining your problem and attach your logs (Status > Logs > Download all logs) to the case for support to review. Please edit the thread title (i.e. subject of first post in the thread) to include your case number.
ProSupport for Business
