sdbosco
Feb 10, 2013Aspirant
ReadyNas Pro won't power down
I have 2 ReadyNas Pro 6 devices, one of them has been acting up. Both are configure the same but one will not power down, it shuts down but then it reboots. I unplug the power from the device between ...
sdbosco
RAIDar version 4.2.22 but the RAID was created under an earlier version about 2-3 years ago not sure what version was the latest at that time. It also worked fine after I upgraded to 4.2.22 it just stopped shutting down one day. Also didn't mention before, once I plug power back in no response when pushing the power button but the ethernet ports are blinking like crazy.... then all of a sudden the (in about 1/2 hour) the fan starts up and boot process starts. Also makes no difference using RAIDar under windows or Mac OS X
Thanks
Thanks
