Cabadam
Jun 29, 2014Aspirant
ReadyNAS reporting drive failure
I previously had 3x Seagate 1.5 TB drives in my ReadyNAS NV+ (v1).
Recently, it reported a drive failure on drive #3, and sure enough, it was making a horrible noise. The drives I have aren't in production anymore, so I replaced it with a 2TB Seagate (ST2000DM001).
It was recognized and successfully rebuilt. However, since that initial replacement, the ReadyNas has reported a disk failure several times, all on this new disk. I pull the disk out, put it back in, and it thinks everything is fine again and rebuilds (succcessfully). A week or so later, it reports it as failed again.
Is this a drive problem? A ReadyNAS problem? Is there a way for me to see why it is failing the drive?
Thanks
Thanks
- StephenBGuru - Experienced UserWhat are the SMART stats on the new drive?
- CabadamAspirantThe disk is initializing since it failed it out earlier this afternoon, and it won't let me get to the SMART info yet. I'll check it once it comes back up.
- CabadamAspirantHere's the SMART info reported by the ReadyNAS:
SMART Attribute
Spin Up Time 0
Start Stop Count 9
Reallocated Sector Count 0
Power On Hours 1560
Spin Retry Count 0
Power Cycle Count 9
Runtime Bad Block 0
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 0
High Fly Writes 0
Airflow Temperature Cel 38
G-Sense Error Rate 0
Power-Off Retract Count 9
Load Cycle Count 11
Temperature Celsius 38
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Head Flying Hours 254777460000279
Total LBAs Written 10220811386
Total LBAs Read 2006893
ATA Error Count 0
Extended Attribute
Hot-add events 5
Hot-remove events 5
Lp stat events 5
Power glitches 0
Hard disk resets 4
Retries 2
Repaired sectors 0 - StephenBGuru - Experienced UserThe main SMART stats look good (no reallocated sectors etc). but the hard resets is not normal, neither are the retries.
