claynz
Aug 19, 2022Guide
ReadyNAS RN-314 Upgrade
I have a ReadyNAS 314, all drives are configured as JOBD RAID1 First off, will the Seagate 18TB ST18000NM000J work ok in this NAS unit? I would like to replace a 10TB drive with 18TB, do I just ba...
claynz
Aug 19, 2022Guide
So destroy the volume, replace the drive, format the replacement, re-create the volume and doing this wont effect the other drives?
I'm not really interested too much in recovery but more in storage as I have 4 16TB drives in my computer and 4 10TB drives in the NAS and all I do is sync between the two with data that has changed, so if I was to lose the data on one device it's still on the other vice versa.
so for single disk usage in a NAS unit
Not sure why it shows RAID1 on the first disk and JOBD type. Is this a correct setup for single disk use? (image attached)
Aug 19, 2022Guru - Experienced User
From the screenshot, it looks like you have 4 JBOD volumes, one for each drive.
Yes, that's the process. The other drives aren't affected. You will need to recreate shares, and any backup jobs that use them. Then restore data.
If you have apps installed: One of the volumes is hosting the /apps folder. If that's the volume you are upgrading, then uninstall the apps before destroying the volume, and reinstall them afterwards. (/apps will end up being hosted on a different volume).
- SandsharkAug 20, 2022Sensei
Yes, it's a lot easier with each drive being a separate JBOD. When I read your first post, I erroneously thought you had all the drives in a single JBOD.
- claynzAug 24, 2022Guide
Apps would be installed on the first drive by default wouldn't it? how would I know?
- SandsharkAug 24, 2022Sensei
Whatever drive they are on, the .apps directory will be re-created another one when you destroy that volume. That's why it's so important to uninstall apps first. When the Apps folder is re-create on another drive, the contents aren't moved.
If you started with just one drive and added another, the apps would be on the first one. If you use SMB to access the NAS and use the admin credentials, you should be able to see where .apps is located (you may need to turn on "show hidden files" in Windows ).
- claynzAug 28, 2022Guide
Yeh, that's what I originally did was start with 1 drive, so apps should be on the first drive which is staying will be replacing the second drive
