dronect
Aug 12, 2025Follower
ReadyNAS RN1020-100EUS – Cannot detect via RAIDar or default IP after reset/recovery
What I’ve done so far: Tried multiple Ethernet cables. One bad cable was found and replaced. Now connected via the same network (router/switch) as my PC. I have also tried a direct cable from NA...
Aug 12, 2025Guru - Experienced User
Try powering down, and removing the disks (labeling by slot). Connect the NAS to your switch/router as it was before.
Then let us know if RAIDar detects it (reporting a no disks status).
If not, then also check your router's attached device list, and see if the NAS is detected/
dronect wrote:Performed a factory default reset using boot menu ...
Hopefully you are aware that this will delete all your data.
