dronect
Aug 12, 2025Follower
ReadyNAS RN1020-100EUS – Cannot detect via RAIDar or default IP after reset/recovery
What I’ve done so far: Tried multiple Ethernet cables. One bad cable was found and replaced. Now connected via the same network (router/switch) as my PC. I have also tried a direct cable from NA...
Sandshark
Aug 18, 2025Sensei
dronect wrote:USB Recovery with rear port:
Built USB manually from a YouTube tutorial (may not have been official RN1020 package)
Booted doing same procedure as default reset but selected disk led 2 instead.
That's not how you do a USB recovery. The reset button isn't used for that. See How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system But try what StephenB suggested without the drives first. If that works, then USB recovery is not what you need.
