SvendSG1
Jul 11, 2016Aspirant
ReadyNAS RN104 Firmware upgrade tp 6.5.1
Been using the divice on LAN for almost 12 month, and apart from the system occasionally disapearing from the LAN, have not had any issues. Although unit registered in ReadyCloud, have not tried to ...
Jul 11, 2016Guru - Experienced User
Is the resync progressing, or is it stalled? (e.g., is the percentage rising?).
Do you recall what firmware you were running before?
