rvijay26
Jan 22, 2020Aspirant
ReadyNAS RN10400 DATA DEAD -> Reboot-> remove inactive volumes to use disk
Current status: No files are accesible and when the drive is accessed via the web interface, I get a message: "Remove inactive volumes to use the disk. Disk #1, 2, 3, 4." Here is what happened: ...
rvijay26
Feb 02, 2020Aspirant
Thanks for your reply! While that does seem like the most likey scenario, I am a bit puzzled because this exact thing seems to have happened to other users. I never got any error messages relating to drive 4 but just when I was resyncing drive 2 , it decides to go bad.
I am in touch with Netgear support and they will be advising me on further steps. I will post an update once I have some solution from them.
Meanwhile, I am wondering if the following reasoning makes sense:
Assuming drive 4 has gone bad but since my original disk 2 is not yet been declared bad, I might be able to recover some data using disk 1, old disk 2 and disk 3 .
I am not sure if the resync operation affected disk 1 and disk 3 as well.
Is there a way to clone these disks and play around with the clones?
Feb 02, 2020Guru - Experienced User
You can clone the original disks to new ones using any tool that does sector-by-sector copying. Clonezilla is one of several.
The disks are likely to be out of sync though, so you might need to forcibly mount the RAID volume. Damage to the file system can include errored blocks on the disks, but also includes inconsistencies that result from the out-of-sync array.
