Dazza76's avatar
Dazza76
Readynas rn316/rn516 with WD 3.5" Red NAS 8TB WD80EFZX
Hello i am looking go purchse a nas either a n516 or a n316, Can they take the WD 3.5" Red NAS 8TB WD80EFZX 128M SATA3 HDD
Can you confirm if these will work i note you have limited options int the 8tb compatability
Cheers
Darren
  • Hi Dazza76,
    I do not have those disks, so I can't answer whether they work fine with the NAS or not. They are not listed on the compatibility list anyway:
    http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list?cid=wmt_netgear_organic
    Perhaps someone else on the forum might be able to answer that question. However, Netgear could deny you support (if you at some point need support) due to the fact that you are using unsupported disks. Personally, I always stick to officially supported disks.
    Cheers!
    • StephenB's avatar
      They work in my RN102 and my RN202, so I see no reason why they won't work in the x86 NAS.  The side holes are aligned with the pins on the tool-less plastic inserts on the disk tray.
      Although the drives aren't on the HCL today, it would be pretty shocking if they aren't added soon.
      • Retired_Member's avatar
        Retired_Member
        I would also be interested to know for the RN316 with these drives - WD Red (NAS) 3.5" 8TB WD80EFZX (5400RPM 128M SATA3), I'm looking at upgrading mine with these too...
        WD claims the RED series are NAS compatible Drives (ie not desktop drives), but do not list this specific 8TB model as tested for Netgear RN 316 yet? found here: http://www.wdc.com/en/products/products.aspx?id=810 - this page claims the following for the RED class of drives (italic'd to highlight):
        "Fill your NAS with WD Red, then fill it with awesome.
        There's an industry-leading WD Red drive for every compatible NAS system to help fulfill your data storage needs. With drives up to 8TB, WD Red offers a wide array of solutions for customers looking to build the biggest, best-performing NAS storage solution. Built for single-bay to 8-bay NAS systems, WD Red packs the power to store your precious data in one powerhouse unit. With WD Red, you're ready for what's next"
        But I also found the following from here: http://support.wdc.com/KnowledgeBase/answer.aspx?ID=996 (possibly old?)
        "Critical: WD Blue, Green, Red or Black hard drives are not recommended for and are not warranted for use in RAID environments utilizing Enterprise HBAs and/or expanders and in multi-bay chassis, as they are not designed for, nor tested in, these specific types of RAID applications. For all Business Critical RAID applications, please consider WD’s Enterprise Hard Drives that are specifically designed with RAID-specific, time-limited error recovery (TLER), are tested extensively in 24x7 RAID applications, and include features like enhanced RAFF technology and thermal extended burn-in testing. "
        Erm, do Netgear use Enterprise HBA's and/or expanders or multi-bay chassis in the RN316? Talk about WD confusion lol
        Anyhow, I note that Netgear have currently NOT listed them as tested/confirmed compatible drives (yet?) - see: http://kb.netgear.com/app/answers/detail/a_id/20641/~/readynas-hard-disk-compatibility-list - but they don't seem to have many 8TB drives tested either....
        I've also noticed Netgear strongly recommends drives with a Rotation Vibration Safeguard feature, which the WD80EFZX  doesn't seem to have specified (presumedly not a feature then), is it a requirement or just a recommendation guideline when not listed yet?
        For them to be listed, do WD and/or NG do the testing? Does it take some time to perform? Are they based on manufacture (ie WD) specs first, then tested? Keeping in mind, these are pretty new drives.....
        My main concern is compatibility and logevity of using such drives with 24x7 automation on a RN 316 with relatively low-medium use for around 3-5 users during the day (other RED's are listed, just not these...only because of no testing done yet?)
        I was reading weinelm's post on WD80EFZX with ReadyNAS Ultra 2 here other than having some possible noise issues (vibration/fan/RPM issue?), otherwise working fine on that RN.
        Sorry for the barraige of questions, but if some could be answered that would be great.
  • I have setup my RN516 with 4 *  8TB WD Reds and working without issue , just a little slow to initilize a new Raid 10 array about a day
    Cheers D
ProSupport for Business
