Scottyd72
Mar 28, 2020Aspirant
ReadyNAS RND4000 v3 (NV+) power supply died, can I put HDs in new ReadyNAS (either RN424 or 3138)?
Hi there, Scott From Newcastle, NSW, Australia - I'm a new user here but we have had our NV+ since 2009 and it has died as the power supply is not outputting anything. Getting another (generic only) ...
- Mar 30, 2020
Scottyd72 wrote:
Or am I just going to have to plug both new and old NAS's into the network and transfer the data across?
This is the path you'll need to take - the new NAS won't be able to mount the old disks. Use a backup job running on the 3138.
Generally I use rsync (though NFS might be a bit faster) - enabling the protocols on both NAS of course. You'll want to reset permissions on the 3138 shares when that is completed.
Scottyd72 wrote:
So is it possible to start up the 3138 with only two 6tb drives in it (what positions should I put them in?)
It doesn't matter what positions you put them in.
Scottyd72
Mar 29, 2020Aspirant
So Just to redo my question as I have been able to decide to replace my NAS (been checking out other threads) and I have ordered a 3138 and so far ordered 2 6tb WD red pro drives.
So is it possilbe to start up the 3138 with only two 6tb drives in it (what positions should I put them in?), then insert two of my old drives in to transfer the data? Or am I just going to have to plug both new and old NAS's into the network and transfer the data across?
Ps. I only need to tx the data, I don't need to save and user acct info...
Thanks to all of you for your guidance so far...
Mar 30, 2020Guru - Experienced User
- Scottyd72Mar 30, 2020Aspirant
Thanks Steven, thats what I needed to find out.
