oscortega
Feb 01, 2022Aspirant
ReadyNas RNR4000 Power supply failure
Hello, Can anyone help with locating a replacement Power Supply for my ReadyNas 1100 - RNR4000? The power supply did not survive a power failure even though it was connected to a UPC. With ...
- Feb 02, 2022
I think I found the right one.
I've never had an 1100 to work with, but believe its power supply does have the small rear-facing fan pictured, so that supply should be good for it. On the other hand, most of the other models listed have no place for the fan to exhaust, so it's not a good choice.
I guess the only questions are whether the picture showing the fan is accurate (that company makes a lot of supplies, and it could be the wrong photo) and if the fan has been disabled to make it more compatible with the listed units (though it would still not have proper airflow for them).
The one listed as "NEW 350W Netgear ReadyNAS NV 1100 RNR4450-100NAS power supply Replacement N1" would seem a safer bet, even though the picture is the same. All of those models do have an outlet for the rear-facing fan *though later NV's shipped with (or were offered a replacement) fanless supply.
It is just a slightly differently wired Flex ATX supply, by the way. You can find the pin-out here: ReadyNAS_PSU_pinout .
Feb 01, 2022Guru - Experienced User
It's the same PSU that is used in the NV+.
There are some for sale on ebay.
oscortega
Thank you for the reply. With your direction I believe I've found a listing on ebay with the title
350W FOR Netgear ReadyNAS RND4000 NV NV+ NVX RND4210 RND4410 power supply N1
- StephenBFeb 01, 2022Guru - Experienced User
good. Maybe wait a bit, and see if Sandshark has any advice to offer.
- SandsharkFeb 02, 2022Sensei
