E1b0t
Feb 23, 2017Tutor
ReadyNAS RR4312 Recommended Hard Drives?
Hi there, Please confirm the correct drives to order for the Enterprise ReadyNAS Devices, we need 10Tb Hard Drives which is required for Video storage Thanx
mdgm-ntgr
Feb 23, 2017NETGEAR Employee Retired
The compatibility list is here. You should stick to disks with Rotational Vibration Safeguard and a 5 year warranty.
E1b0t
Feb 23, 2017Tutor
Thank you for the reply. I needed to structure the question better...
Which one of the 10TB drives listed on the list is recommended for the above application. If you have to chose one, which one will it be?
IronWolf?
