owoodruff
Mar 18, 2016Aspirant
ReadyNAS setup and use newbie
Hi there, I'm looking for some help setting up my ReadyNas and linking it with my readycloud etc. I've followed a few threads and appear to have the thing turned out, discovered and visible in t...
mdgm-ntgr
Mar 20, 2016NETGEAR Employee Retired
You need to setup an application specific password in Gmail so that your email alerts can work. See https://support.google.com/accounts/answer/185833
You are getting frame errors, dropped packet errors and the NAS is connected at 100 Mb/s.
We would like to have a remote look at your NAS. I have sent you a PM.
- StephenBMar 20, 2016Guru - Experienced User
That is one way, but not the only way. Disabling 2-factor authentication and allowing "less secure apps" also works.
