PSC123
Jul 25, 2017Aspirant
ReadyNAS Surveillance
Hi, I have an RN3138 and I'm looking to install RN Surveillance and buy a camera licence, but the last compatibility list on the web seems to be from 2012, and I can't find a landing page for product ...
JennC
Jul 26, 2017NETGEAR Employee Retired
Hello PSC123,
Yes, this app/add-on is still being used. You may download information about ReadyNAS Surveillance from the Netgear downloads page, just use the part code of ReadyNAS Surveillance, RNNVR01L-1000S.
Cameras that are on the compatible camera list are the ones approved and tested.
- StephenBJul 27, 2017Guru - Experienced User
Note this list hasn't been updated for 3 years, so hopefully the cameras you want to use are still available.
- PSC123Jul 27, 2017AspirantYes, thanks. This list is next to useless on the basis it's so old. Does anyone have any experience of a suitable HD 1080p bullet camera that is compatible? Thanks in advance.
- Nov 24, 2016Retired_Member
