aegon
Mar 10, 2021Aspirant
Readynas to pc and internet connection
Hi All Apologies if this is in the wrong place, first time. I hope someone can help me. This is the setup. PC is connected to the Internet via wifi (cannot run any network cables) I have conne...
- Mar 11, 2021
Hi All
Thank you for replying i really appreciate it. i did find a solution. But first only fair to answer the questions;
*the router is downstairs front room, at the moment i cannot run a cable to the upstairs backroom where i use my computer.
*not appropriate at the moment to keep the nas near the router as i do not have space and sockets.
*im using a pc windows 10
any as StephenB mentioned - i shared my wifi connection with the Ethernet connection and works great, i did not even know it possible .. i did try it a few times did not work, but after resetting and then trying again it worked. and is working great.
this is the link i found: https://youtu.be/xpTO0zaeqiY
Sandshark
Mar 11, 2021Sensei
A WiFi access point is one possibility.
