dannieboiz
Aug 17, 2018Tutor
Readynas trigger drive as Dead but CrystalDisk shows disk in good health?
This will be the 2nd WD Red drive that the NAS reports to be dead on a ReadyNAS Duo V2. I removed it and tested it on a PC and everything works. Checked with CrystalDiskInfo and it says the drive is ...
dannieboiz
Aug 17, 2018Tutor
Before putting it in the other nas, I deleted all the previous partitions and format the drives. So the drive is for sure empty with no partitions
Aug 17, 2018Guru - Experienced User
I suggest using Lifeguard's write zeros test (zeroing the full disk). I've found that turns up issues that the non-destructive tests miss.
