Dark_Stranger's avatar
Feb 23, 2013
ReadyNas Ultra 2 - Largest supported drive
Guys, I have just brought a Ultra 2 and from my understanding it only supports 2 x 2tb drives, but on the compatibility list it mentions 3tb drives. Can someone confirm what the largest drive I can put in the Ultra 2? I was hoping 2 x 3tb's.
Thanks,
Stu
  • StephenB's avatar
    The ultra 2 supports 3 TB drives (and several are listed on the HCL here: http://www.readynas.com/?page_id=82) You should stick with the HCL.
    I suggest the western digital WD30EFRX. Search this forum for the specific drives you are considering before you purchase. Some of the choices on the HCL haven't worked out so well.
ProSupport for Business
