readyram's avatar
Jan 02, 2020
ReadyNAS Ultra 2, OS 6, Dead volume
Hello   I have an old ReadyNAS Ultra 2, running OS 6. I was trying to set up MySql on it when the frontend suddenly failed and I had to do a har reboot. When it booted back up the volume was missi...
  • Marc_V's avatar
    Jan 02, 2020
    readyram
    Your System root volume is at 100%. The services failed to start and getting your volume md127 to stop. I don't think there are issues with the disks (smart_history and diskinfo)
    If you are comfortable with SSH you will be able to remove the files or data that consumed the System volume and restart the RAID. Contacting Support is not an option but the Community might be able to help.
    If you have full backup of data, Factory reset is another option.
    Hope this helps!
    Regards
ProSupport for Business
