btran33
Dec 15, 2015Aspirant
ReadyNAS Ultra 2 Plus can't find on Raidar/network
Hi All: I hope someone could help me with my Ultra 2 plus. I got this used NAS from CL and hope to use it for backup and streamming music/movie to my hometheater mediaplayer. The previous owner sw...
btran33
Dec 17, 2015Aspirant
HI Brian: So Sorry, but I'm so new to this NAS and really have limitted Computer/network skill. Can you show me how to do the direct connection? as of IP address, yes it has the same IP address as my network IP when I'm able to ping it, just for a quick moment when it's set up the disks. But then it would just gone from the network! very weird! One mininute it's there then it just gone! the network lights is still blinking and fans runing, both driver lights is on, but I can't ping it or find it on the network!
thanks
bt
Dec 17, 2015Guru - Experienced User
Brian linked to the direct connect procedure here: http://kb.netgear.com/app/answers/detail/a_id/21414/~/how-do-i-direct-connect-between-readynas-and-pc%2Fmac%3F
If you are using dhcp/automatic IP address assignment in the NAS, you
(a) directly connect the NAS ethernet cable to the PC
(b) assign IP address 192.168.168.100, gateway address 192.168.168.1, and subnet mask 255.255.255.0 to the PC (a temporary static address).
Then see if you can ping 192.168.168.168, and access https://192.168.168.168/admin
If your NAS is using a static address (and you would have had to configure it that way) you
(b) assign IP address 192.168.1.2, gateway address 192.168.1.1, and subnet mask 255.255.255.0 to the PC (a temporary static address).
Then see if you can ping 192.168.1.22, and access https://192.168.1.22/admin
You might want to arrange for per-incident support.
- btran33Dec 18, 2015Aspirant
Hi:
I tried the direct connect the Nas to my computer yesterday follow your direction, but still can't ping or see the Nas in Raidar. I read on one of the post, can't seem to find it now, that someone had the same problem as mine and said that it's a firmware corrupted in flash memorry. Is there a way I can flash this ultra Nas with new firmware? I see the instruction for OS6 and for ARM system but not for X86 system.
thanks
bt
- StephenBDec 19, 2015Guru - Experienced User
Unfortunately, Netgear won't support used NAS.
Have you tested the disks with seatools? If not, then you probably should. Running a memory test from the boot menu is also something you can try.
It is possible to do a USB boot recovery, but there is some risk. Perhaps wait a bit, and see if one of the Netgear posters chimes in. But I suggest that you try the suggestions above first.
- mdgm-ntgrDec 20, 2015NETGEAR Employee Retired
I would suggest trying StephenB's suggestions in the order that he gave.
