btran33
Dec 15, 2015Aspirant
ReadyNAS Ultra 2 Plus can't find on Raidar/network
Hi All: I hope someone could help me with my Ultra 2 plus. I got this used NAS from CL and hope to use it for backup and streamming music/movie to my hometheater mediaplayer. The previous owner sw...
Dec 23, 2015Guru - Experienced User
It could be a corrupt flash.
But USB recovery might not fix it - the flash also contains the serial number and other product identication, and only netgear can fix that. Maybe PM mdgm and see if he offers some advice.
btran33
Dec 23, 2015Aspirant
Thanks StephenB!
mdgm, I would greatly appreciated if you can help flash the firmware on my Ultra 2 Plus.
Thank you,
Bao Tran
- mdgm-ntgrDec 28, 2015NETGEAR Employee Retired
I have sent you a PM.
The firmware on the flash was indeed corrupt. This problem is only seen in some cases when doing a factory default.
Your system had no data on it and should be fixed now and doing another factory default.
- Arvid_SulsJan 09, 2016Aspirant
Hi mdgm,
I have most likely the same problem with my Ultra 2. It started when I took out the two 1TB disks (WD Red) that were already in for a few years and when I plugged in a brand new WD RED 4TB disk. Disk and memory test seems perfectly fine. I did a factory default and initiated via RIADar the setup of the 4TB disk (X-raid2). After in RIADar the 100% is reached, the NAS becomes unable to find via RAIDar.
I still had one of the 1TB drives,and it worked fine when I put it back in. But performing a factory default (and build X-Raid2) with this 1TB disk also didn't succeed. I also tried another new 1TB disk (WD red) from work, and also with this disk I couldn't get the Ultra 2 to work again. So, on several forums I found that this was most likely due to a corrupt flash???
I tried via a Netgear USB recovery tool to flash RAIDiator-x86-4.2.28 again on the NAS, but without success. I started looking further on the web and come upon this discussion. The only time I can see the NAS via RAIDar is after factory default and for the few minutes I can observe the NAS also no firmware is noted. If I use a network discovery tool (like Fing on Andriod) I can see that the IP adress is unchanged, but opening the admin page via the webbrowser is not possible.
Can you please help me?
Thanks Arvid
- Arvid_SulsJan 13, 2016Aspirant
mdgm also fixed my Ultra 2 unit. 1000x thanks!!!!!!!
- eianeianJan 22, 2016Aspirant
Hi,
Please help me as well. I have a ReadyNAS Ultra 2, that will not boot. When I do factory reset, with one disk - it shows in the Raidar. Once I choose disk options, nothing more happends.
I can find the device on the network (ping), but not in the browser or raidar.
Thanks,
/E
- StephenBJan 22, 2016Guru - Experienced User
What firmware is on the NAS? Have you tested the disk in a PC with the vendor tools? (Seatools for Seagate, Lifeguard for Western Digital).
It was upgraded to the latest version for x86, 4.2.28. No, I have not tried the disks - but they did work before I did a factory reset (i wanted a clean install).
Can anyone provide a guide for usb-flash the firmware or similar?
