PederMyhre's avatar
PederMyhre
ReadyNAS Ultra 4 Change defective HD still dead
Hello!
I have read all the topics about dead harddrives but i still dont understand the solution to my problem.
I have 4 disks running: RAID Level X-RAID2, 4 disks
Disk 2 went dead (I took it out and connectet it to a computer, it didn't find it and made funny sounds)
In the front view it also tells me that disk 2 is dead.
I hotswapped it with a new one (checked the compability list and the disk is in that list)
In the log it says: Data volume will be rebuilt with disk 2.
After a few days the Frontview says the disk is dead and C: is unprotected.
I did a reboot of the nas, same message and nothing more happens.
Turned the nas off and took out the disk, startet the nas and inserted the disk when up and running. In the display it shows Testing disk 2, then Disk 2 passed, in the log it says: New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2] and: Data volume will be rebuilt with disk 2.
In the health window in frontview it still says disk 2 dead.
I have the latest firmware and the NAS is up and running on 3 disk's.
Why is disk 2 still dead and why doestn't resync show up?
And in the health window the modelnumber of the old drive is still showing.
  • StephenB's avatar
    What firmware are you running in the ultra?
    Also what disk model are you using?
    Try hovering your mouse over the volume icon at the bottom of the web UI.  That should give you some volume status also, please let us know what it says.
    • PederMyhre's avatar
      PederMyhre
      I'm running RAIDiator 4.2.31
      The old disk's are Segate ST20000DL003 (In bay 1,3,4)
      The new disk is Segate ST2000DM006 (In bay 2 )
      In the disk status it's still ST20000DL003 in bay 2, but it should be ST2000DM006, and not showing temperature.
      • StephenB's avatar
        FWIW, a Seagate Ironwolf would have been a better disk choice.  Seagate DMs don't have a good track record with RAID.  The HCL hasn't been updated for years now, so it isn't a useful guide anymore.  You're better off getting a current NAS-purposed drive (Seagate Ironwolf or Western Digital Red) or an enterprise-class disk. I don't recommend desktop class drives for NAS use anymore.
        I think the next step is to pull disk 2, and test it in a Windows PC with Seatools.  You can connect it to the PC either with SATA or a USB adapter/dock.
ProSupport for Business
