homeric
Aug 03, 2021Aspirant
ReadyNAS Ultra 4 hangs on booting
My Ultra 4 now hangs at the "Booting..." message when I try to start it up normally. Previously, disk 4 had failed, and I tried replacing it with one with matching specs (WD Red 3 TB). The new di...
- Aug 03, 2021
The WD30EFAX? or the WD30EFRX? The EFAX is an SMR drive, so I'd recommend exchanging it for the EFRX.
homeric wrote:
Then the unit became unresponsive. I had requested a download of all the log files just before that. Not sure why that would be fatal, but it did seem to be cause and effect.
I've tried running the disk test from the boot menu. All three existing disks tested successfully. The unit shows up in RAIDar 6.5 with check marks next to the disks. I haven't tried pulling the disks and testing them separately.
Did you try booting it up w/o the new disk (skipping the file system check)?
If that still doesn't work, you could try entering these commands in tech support mode:
start_raid.sh mount /dev/md0 /sysroot mount --bind /proc /sysroot/proc mount --bind /dev /sysroot/dev mount --bind /dev/pts /sysroot/dev/pts mount --bind /sys /sysoot/sys chroot /sysroot /bin/bash vgscan vgchange -a y mount -o ro /dev/c/c /c
If all this works, the data volume should be mounted as read only.
Aug 05, 2021Guru - Experienced User
I'm glad you got it working. Thanks for posting your other steps, as I think they will be useful to others.
homeric
Aug 05, 2021Aspirant
StephenB wrote:I'm glad you got it working. Thanks for posting your other steps, as I think they will be useful to others.
Thanks again, couldn't have done it without you.
In terms of the other steps, I finally figured what I was missing on the rsync command. I meant to say:
rsync -avuP /c/oldshare/ /mnt/newshare
with a slash after "oldshare". So when copying "media", what would give "newshare/Music", "newshare/Pictures", and so on.
I had to get out my Unix glasses, I guess staring at Windows is not good for you.
What I did initially was:
rsync -avuP /c/oldshare /mnt/newshare
without the slash, so I got "newshare/media/Music", "newshare/media/Pictures", and so on. That wasn't quite what I intended, but no harm done.
(Edit: found the edit button, tweaked the formatting.)
