treno
May 26, 2013Aspirant
ReadyNAS Ultra 4: how to stop the fan from making noise
I used to own an Ultra 2 and I was really happy with it. It was sitting under my desk and it made no noise from the fan. Now I bought an Ultra 4 to have room for expansion. While the Ultra 4 is a n...
treno
May 29, 2013Aspirant
Chirpa,
correct me if I'm wrong (I'm guessing, but I didn't experiment with the selfcontrolled parameter):
I guess that your script fixes fan speed regardless of temperature, or not?
If I'm right isn't it a little bit dangerous in case of high load /high temperatures?
Don't you think that editing the enclosure.db file is slightly "cleaner"? (you can also change the selfcontrolled parameter in that file).
