treno
May 26, 2013Aspirant
ReadyNAS Ultra 4: how to stop the fan from making noise
I used to own an Ultra 2 and I was really happy with it. It was sitting under my desk and it made no noise from the fan. Now I bought an Ultra 4 to have room for expansion. While the Ultra 4 is a n...
el_patron
Jul 27, 2013Tutor
chirpa wrote: I do fix the fan speed yes, though I have it in a controlled environment. I used to have a cron script running to periodically check the temps and raise the fan a bit, but haven't need it in awhile.
Hi chirpa,
can you share examples of the scripts for this temp/fan control and where you put them on the filesystem? This would be great!
patron
