Keper
Jul 25, 2023Guide
Readynas ultra 4 operating system setup
Good day. I have Readynas Ultra 4 with xpenology installed Tell me, is it possible somehow to return the native operating system?
schumaku
Jul 25, 2023Guru - Experienced User
Have changed booting from the internal device instead of an external USB?
- KeperJul 25, 2023Guide
Apparently yes
- StephenBJul 25, 2023Guru - Experienced User
Is there a reason why you want to change back?
Keper wrote:
Apparently yes
Then likely you can't revert.
Try this test:
- power down the NAS
- remove all disks (labeling by slot)
- insert a test disk (which will be formatted)
- use the boot menu to do a factory default
- see what OS is installed on the disk.
The factory default via the boot menu is described on pages 21-22 of the hardware manual:
Reinsert the disks with the NAS powered down.
The server starts but does not boot. Nothing lights up on the display.
