xaero
Nov 01, 2011Guide
ReadyNAS Ultra 4 with WD10EARX, Clicking noice when idle
Hello!
I recently bought the ReadyNAS Ultra 4 and loaded it up with 4x1TB Western Digital WD10EARX Green. I run the disks in X-raid2 (Raid 5 on 4 disks) and the performance is great.
Now, the “problem” I have encountered is the same as many others have with the Western Digital Green-series. The drives make a clicking sound when they are idle which apparently is caused by the power saving feature Intellipark. (See link)
http://community.wdc.com/t5/Desktop/WD10EARS-makes-quot-clicking-quot-noise-when-idle/td-p/172162
Now, there is a solution, which is to either disable Intellipark or extend the time period before it is activated. Default value is at an aggressive 8 seconds (!).
http://www.ngohq.com/news/19805-critical-design-flaw-found-in-wd-caviar-green-hdds.html
My question now though is how I apply this fix to the disks without tearing down the raid array? Have anyone managed to solve this with the disks still in the ReadyNAS?
Thank you kindly!
Thank you kindly!
- xaeroGuideI just want to clarify that it is indeed the WD10EARX (X, not S) that I am asking for help with.
- xaeroGuideI have now solved this problem with wdidle3.exe disabling the intellipark timer completley. I did however do it the hard way by removing the disks from the NAS, mounting them one at the time in a computer, booting DOS and run wdidle3.exe /D
