GregGT13
Nov 17, 2019Aspirant
readynas ultra 6 won't boot
I have a ReadyNAS ultra 6 that won;t boot past the "ReadyNAS" logo unless I take the disks out. Then it boots to "no disks." I can get to the boot menu, but only when the drive bays are empty. I read...
Nov 17, 2019Guru - Experienced User
GregGT13 wrote:
I read that this may be a failed power supply.
It sounds like the most likely possibility to me.
Though I guess you could run the memory test.
Also, if you have a spare disk you could try doing a factory install with just that disk in place.
- GregGT13Nov 17, 2019Aspirant
If I reset to factory defaults with a spare disk, should I have any trouble reading the original volume?
- StephenBNov 17, 2019Guru - Experienced User
No. All the settings are on the current disks (as well as the OS partition that the system boots from).
- GregGT13Nov 18, 2019Aspirant
I reloaded the firmware and ran a memory check and a disk check. I had to boot it to the boot menu with no drives, then put the drives in and ran the disk check. When it finished it booted normally.
