GregGT13
Nov 17, 2019Aspirant
readynas ultra 6 won't boot
I have a ReadyNAS ultra 6 that won;t boot past the "ReadyNAS" logo unless I take the disks out. Then it boots to "no disks." I can get to the boot menu, but only when the drive bays are empty. I read...
GregGT13
If I reset to factory defaults with a spare disk, should I have any trouble reading the original volume?
Nov 17, 2019Guru - Experienced User
No. All the settings are on the current disks (as well as the OS partition that the system boots from).
- GregGT13Nov 18, 2019Aspirant
I reloaded the firmware and ran a memory check and a disk check. I had to boot it to the boot menu with no drives, then put the drives in and ran the disk check. When it finished it booted normally.
- SandsharkNov 18, 2019Sensei
It may have been something on the drives (htough i don't know why what you did would fix that), or your power supply could be on its last legs (nd it's hit or miss to overcome the extra load of power-on). The NAS will display "ReadyNAS" if just the +5V is working. A bad 3.3V or +12V could keep it from booting. That removing the drives helped suggests the +12V, since the drives use that and not 3.3V.
I'd make sure you keep your backup up to date and be prepared for the possibility of it occurring again, possibly not recoverable next time.
Thanks!
