jamesevarts3
Nov 03, 2018Aspirant
readynas ultra 6
i have a readynas ultra 6
i can connect to it with netgear raidar 4.2.31.
the admin page and locate buttons work but the browse does not
when i click the browse button, it bring up my DOCUMENTS...
- Nov 05, 2018
jamesevarts3 wrote:
when i type \\nas-name or \\nas-ip-address it says windows cannot access
i am running windows 10
Have you gone into "turn windows features on and off" and made sure that the SMB 1.0 client is enabled on the PC?
Microsoft is deprecating SMB 1.0. but your NAS doesn't support anything newer. So you do need it enabled to access the NAS.
Nov 04, 2018Guru - Experienced User
Can you connect to the NAS by entering \\nas-name or \\nas-ip-address into the Windows File Explorer Address Bar?
Are you running Windows 10?
jamesevarts3 wrote:
raidar 4.2.31.
4.2.31 is the firmware your NAS is running. RAIDar's version is likely 4.3.8 or 6.4 - it would be helpful to known it.
jamesevarts3
Nov 04, 2018Aspirant
i am running raidar 6.4.0
i also have anything PC setup the exact same way (just incase my primary pc goes down i have another, and netflix in the background) and my nas works fine, browse button going to the server, not documents
- jamesevarts3Nov 04, 2018Aspirant
another PC, not anything PC
- StephenBNov 05, 2018Guru - Experienced User
- jamesevarts3Nov 05, 2018Aspirant
ty, that was it
