vertigo2712
Nov 04, 2012Aspirant
Readynas Ultra6 horrible experience: 4 drives dead now!
I regret buying a ReadyNas Ultra6. I've had 4 Readynas 4-drive units in the past and they've all performed well. The 6-drive unit has been a total disaster. I had the previous unit replaced by Netge...
mdgm-ntgr
Nov 04, 2012NETGEAR Employee Retired
What firmware is on those SeaGate disks? You need CC3D firmware or newer on that model.
The Hitachi isn't reporting a valid temperature so I'd think that disk is definitely dead.
Open a new support case and post your case number. Hopefully they can take a look at your logs and perhaps remotely login to investigate.
Disks can and do fail at any time. Also it's possible you may have got disks from a bad batch of Hitachis.
Did you know that you could have configured your NAS to use dual-redundancy so that if any two disks failed data remains intact?
