norbert1
Dec 13, 2011Aspirant
readynas ultra6 RNDU6000
Readynas ultra 6 RNDU6000 supports single volume for all disks? I have older readynas and now I want bigger one but I want to have single volume consisting of 6 2tb drives. thanks
mdgm-ntgr
Dec 14, 2011NETGEAR Employee Retired
Yes after transferring your data across you should be able to do a factory reset on the 600. I would suggest updating the 600 to RAIDiator 4.1.7 or later before doing the factory reset if possible as factory reset on 4.1.7 or later gives 4k sector alignment.
