RPB123's avatar
RPB123
ReadyNas Unknown Users e.g Guest
Hi All,
Looking at the logs for our ReadyNas we appear to have logins from ‘guest’ - what does this mean?
I see there is a ‘guest’ tick box for access to some of the folders. However, there is no ‘guest’ option under the user lis.
There are also some other users called ‘Scan’ and ‘System’ what are these and are either required?
    • RPB123's avatar
      RPB123
      Hi,
      Its a ReadyNas 312
      Firmware is 6.10.3
      • Sandshark's avatar
        Sandshark
        Sensei
        Guest is a non-removable user, so you don't see it in the GUI.  You can see all the users, including several internal users (that you should not mess with) in the /etc/passwd file, either via SSH or in the downloaded configuration file.  If somebody else has access to the NAS, they may be using guest credentials without really realizing it.  Otherwise, you have a problem and your NAS may be compromised.
        I have disabled guest access on all shares, even though i beklieve my NAS is secure..  Windows doesn't really work well with guest credentials, anyway,
        Scan and System are not normal default users.  Unless somebody else set the NAS up for you and added them for some reason, or an app added them (for what purpose, I cannot say -- that would be unusual), then you have a problem.
  • StephenB's avatar
    It means that some devices are accessing the NAS without using credentials.
    You can of course deny guest access if you want, and then create credentials for those users (or force them to apply the credentials they already have).
    What apps do you have running on the NAS?  Is file indexing enabled?
ProSupport for Business
