zorgie
Sep 04, 2015Aspirant
ReadyNAS v.6.2.4 btrfs recovery
Hi, my storage can't mount /dev/md127 after reboot. In process tree i see mount /dev/md127 in D state. Dmesg says: btrfs: corrupt leaf, slot offset bad: block=449773568,root=1, slot=196
btrfs...
mdgm-ntgr
Sep 04, 2015NETGEAR Employee Retired
Do you have a backup of your data?
Your volume is very full. You shouldn't fill it that much.
If you don't have a backup you may wish to consider contacting support and to enquire about the costs involved with a data recovery attempt.
zorgie
Sep 05, 2015Aspirant
thanks for reply,
there is no backup data in my storage. May be i can rebalance data on FS or mount it and delete unnecessary files?
