cmarino3
Dec 31, 2024Aspirant
ReadyNAS V2 Duo - no web access
Hello,
a friend gave me an old, unused RND2000-200EUS (ReadyNAS DUO V2) to play with, so I installed a new hard drive, hard reset the NAS, and it seemed to work fine. I could access the web interface using a modified Firefox with TLS 1.0 enabled and it worked just fine. I set network foders, backups and all, and it all seemed to work.
Now I see the shared folders from other computers and I'm able to use them properly, but the NAS is inaccessible via web. Typing the IP Address gets a ERR_CONNECTION_REFUSED.
Typing a complete address (eg. https://192.168.1.102/admin/dashboard.html ) seems to get to the NAS graphic interface, but it gives a "Device is offline" error.
What should I do now?
Thanks
Normally you'd use https://192.168.1.102/admin
Did you try rebooting it?
- cmarino3Aspirant
Yes, apparently turning it off and on solved it. Very strange. I hope it won't keep happening.
Thanks
