Simmo_79's avatar
Simmo_79
readynas+ V2 RND400 web interface stuck
I'm having trouble with my readynas+ v2, when trying to access via web interface (only can use internet explorer because security certificate error with other browsers). The interface gets stuck/frozen.
Not sure what is causing the problem with interface. 
I have tried reinstalling the OS but has no effect, main reason why I wanted to access Nas via interface is so I can update the firmware as I can't use chrome (security certificate issues).
I can still access files on hard drive through windows.
Can someone help please.
  • StephenB's avatar
    What firmware are you running now?  Current version for your NAS is 5.3.11 https://kb.netgear.com/25787/RAIDiator-arm-Version-5-3-11-for-ReadyNAS-Duo-v2-NV-v2
    RAIDar might be able to tell you what you are running now.  https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
    It might also provide other useful information on the NAS health.
    Certificate issues can be clicked through (often by clicking on "advanced", and then proceeding to the website).  There's a more difficult issue at the moment, because browsers (including Chrome) are dropping support for TLS 1.0 - which is only version your NAS supports.  That creates a protocol mismatch error (not the same as a certificate warning).
    IE still works however, so I don't think this is your problem.
    The top priority right now is to back up the files, because your data is at risk.  So I suggest doing that right away.  Then we can continue troubleshooting what is going on with your NAS (which sounds like it is more fundamental than a browser-related issue).
    • Simmo_79's avatar
      Simmo_79
      Thanks Stephen,
      I have checked with Raidar and the Nas firmware version is 5.3.8 and shows healthy as shown in pic.
      Is there a way to upgrade nas firmware without using web interface?
      I tried seeing if this has a usb boot but seems like there is no option.
ProSupport for Business
