ryanmacl
Jun 23, 2012Aspirant
ReadyNAS Value Added Resellers
I currently have a ReadyNAS Pro 6 with 6 3tb drives in it with dual redundancy, and I am quickly running out of space. My initial idea was to use dual redundancy and drop down to single redundancy as...
BikeHelmet
Jun 30, 2012Aspirant
PapaBear wrote: If you are going to go with 6x4TB drives, start with one and then add them one at a time to make sure each one is individually accepted. Then once the last drive has been resynched, perform a factory default before you copy over any data and before you customize the configuration. Then once the resync has been done you would be beyond the 16TB limit (if single redundancy, if dual redundancy you would still be just under the 16TB limit with a net volume of about 14.4TB).
Good advice. :)
Ah ha! $229.99 for 4TB. Probably the best deal available right now on tons of capacity.
http://ncix.com/products/index.php?sku= ... omoid=1382
